I have created a houdini.env file in the root directory to load Redshift, but it looks like it is not being taken into consideration when Houdini starts. To test I set HOUDINI_UISCALE = 150 to get some visual feedback as to whether the variables are being loaded, and it makes no difference whatsoever.
This is the content of my .env file:
# # Houdini Environment Settings # # The contents of this file are read into the environment # at startup. They will override any existing entries in # the environment. # # The syntax is one entry per line as follows: # VAR = VALUE # # Values may be quoted # VAR = "VALUE" # # Values may be empty # VAR = # # Example: # HOUDINI_NO_SPLASH = 1 HOUDINI_DSO_ERROR = 2 PATH = "/usr/redshift/bin:$PATH" HOUDINI_PATH = "/usr/redshift/redshift4houdini/15.5.571;&" HOUDINI_UISCALE = 300
Any ideas what I am doing wrong ?
