the new attribdataid function returns an integer array of length 4.
while the last array element is clear and can be seen also in the node info, i was wondering what the first 3 entries are referring to.
screenshot attached
atrribdataid array length
1959 4 1- fuat
- 534 posts
- BabaJ
- 2038 posts
From the docs:
As for a potential purpose of using this function and why it doesn't matter what the layout/elements represent:
…The length and contents of the array are not defined, and no assumptions should be made about the layout. The result will vary from run to run of Houdini, so only exact equality should be used….
…If the data id of an attribute is the same as you've seen before, you can assume the attribute contains the same data it did before….
- fuat
- 534 posts
- jlait
- 6189 posts
- fuat
- 534 posts
