blast vertices group!?
   1169   1   0
Hi!
I grouped all vertices in the 0 to 1 range in the UVs. I'd like to delete those polygons with a blast but I can't set it to vertices. I also tried using the group promote sop to set the group as primitive but it doesn't work…
Any advice?
Thanks.
-Olivier
Ah! Found a trick!
I used the attribute promote sop to get the UV info onto the primitives. From there, I grouped primitives that could be blasted.
-Olivier
