Randomization on Scattered Points
   892   0   0
in the attached file, I created a heightfield, scattered points on it, created two piece of geometry with a switcher that are scattered over it. I want to use the for each loop to randomize parameters on the box size, switch nodes etc, but I don't have the code quite right. I would like some values to be between the range of 0-1 while others need to be random per point. I have been playing around with different bits of code, but none is quite right.
point(“../foreach_begin1”, 0, “piecenum”, 0)
point(“../scatterPlants/foreach_begin1”, 0, “piecenum”, 0)
thanks,
Adnan
scatterRandomTerrain.hiplc (1.8 MB)
