Hi!
I followed a tutorial on entagma about doing Spline Wraps. It's very nice for deforming objects but it requires flattening the geo before using the matrix. Doing so results in very funky normals.
Any way to preserve my custom normals?
http://www.entagma.com/rebuilding-the-c4d-spline-wrap-deformer-in-houdini/ [www.entagma.com]
-Olivier
deform with matrix but keep normals intact ?
2314 4 0- olivierth
- 1004 posts
- spagano
- 10 posts
- olivierth
- 1004 posts
It does half the work. When I use the attribute copy sop, I can transfer the normals. The problem is, if a normal on the source object points upward, and the matrix turns the geo upside down, the normal will still point upward.
I'm guessing I need to apply the matrix not only to the @P but to the @N as well. I'll test it out.
Thanks for helping!
-Olivier
Thanks for helping!
-Olivier
- jsmack
- 7737 posts
olivierth
Thanks for helping!
-Olivier
There is a node for applying a matrix to all attributes that are “transformable” at once. It is called “Transform by Attribute”; it can accept a 4x4 matrix point attribute, as well as some other types.
Using this node, you don't have to modify vex code whenever you change the number attributes that need to be transformed.
- olivierth
- 1004 posts
