The Alpha attribute doesn't work when export as fbx file
2635 2 0- EricSheng
- 159 posts
So let's create a simple scene, a box with Cd and Alpha attributes with some randomization.
It's works well so far, so I export the geo as fbx to other application(Unity3d or C4D) but the Alpha attribute doesn't works.
I re-import the geo with the file node, and I find the strange attribute named "Alpha2“ holds correct alpha value. And the ”Alpha" attribute gets the wrong value.
Is it a bug or something else I don't know?
I get the same result in H17 and H16.5
I attached the simple scene if you want to test.
Edited by EricSheng - Oct. 25, 2018 23:04:05
- EricSheng
- 159 posts
- dpernuit
- 534 posts
