H17 Masterclass: Vellum Overview - by Jeff Lait
2526 4 1- chrishebert
- 92 posts
- Andr
- 900 posts
- tamte
- 8449 posts
Andrif you use for example Vellum Cloth shelf tool, then look into created cloth_vellum object, you will see geometry and constraint geometry imported from dopnet, run through vellum_io and Vellum Post-Process
I was wondering what is the workflow to apply the vellum postprocess after your dopnet containing the vellum simulation?
so the key is to import Geometry and ConstraintGeometry separately and then plug to Vellum Post-Process
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- TwinSnakes007
- 589 posts
- Andr
- 900 posts
Now I understand! Thanks a lot Tomas
Daryl do you mean this?
http://www.sidefx.com/docs/houdini/dyno/vellumattributes.html [www.sidefx.com]
Edited by Andr - Nov. 2, 2018 11:23:10
