I've got a small farm of just three machines (one workstation and two ‘renderboxx’ machines all on windows) and a synology box.
Hqueue connects to everyone and I can write small efficient ifds no problem!
However, once they've been written none of my machines can find them! Hqueue shows the path it's trying to access which I can copy/paste into an explorer window to verify that the path is correct and there are indeed ifds there!
I've tried changing the Houdini access method to 2 with no luck!
I'm stumped. The only odd thing about my setup is that it doesn't have internet access. They all talk to each other over a switch. (Activated the licenses then took them all offline per company policy).
I suspect this is really a synology issue not a Houdini one but I thought I'd try the forums just in case someone else has had a similar issues.
Mantra can't find the ifds!
1490 3 2- The3DStig
- 126 posts
- Nicolas Heluani
- 280 posts
The only thing I could think of is to check out all licences are properly working after you disconnected the machines?
Also this helped me…http://www.madguru.com/learn/working-with-houdini-hqueue-windows [www.madguru.com]
On that note,I think old houdini indie licences used not to be able to create ifds files, I think that its not the case after 16.5, but not so sure.
- The3DStig
- 126 posts
I suspect licensing could be the culprit. I'll try refreshing the license manager.
And I should've mentioned that I'm using Houdini FX- this is in my main office. I've been using Indie for my freelance work offsite and complaining about Max/Vray long enough that my management caved and bought me a seat of FX.
- Nicolas Heluani
- 280 posts
The3DStigMore the reason to check, I think Houdini FX licences do not come with extra mantra licences, but I may be wrong.
