Hi everyone,
I made a OTL with a point SOP inside and the values for the position are managed by the Type Properties something like $TX+rand($TZ)/10.
But it doesn't work. All points have 0,0,0.
If I match rurrent definition I get the red arrow and I press to read the error message but while I press the red arrow's gone away. Hmmm
The last line in the message box is “Synchronized with definition”
Any idea? Thanks for help
Detlef
Point Expression within OTL
3821 5 2- winkel
- 217 posts
- pbowmar
- 7024 posts
$TZ won't work in the parameters of an OTL since it's a local variable that only works inside the Point SOP… What you have to do is use $TZ in the point SOP itself. If you want, you can use ch() expressions to let the user control stuff from the OTL interface like
$TZ/ch(“../myparm”)
Peter B
$TZ/ch(“../myparm”)
Peter B
- winkel
- 217 posts
Thanks for that fast reply!
How stupid I am? Mybe too much soccer here in Germany ;o)
Is there a source to find more detais? Inside the OTL is a point SOP (point4) that deforms the incoming geometrie and I want the user to change the expression or only one variable - I don't know to give a variable into an subnetwork that is an OTL….
Please no more soccer… ;o)
Detlef
Detlef
- pbowmar
- 7024 posts
- winkel
- 217 posts
- stevenong
- 1631 posts
