Hello everyone.
Could somebody give an understandable general explanation about the SOP Solver inside a DOP network? When should I use it? And why instead of a POPWrangle? If it is a Solver, where is the previous frame?
I dont understand neither this from the documentation:
“By using an expression like stamps(”../OUT“, ”DATAPATH“, ”../.bjname/Geometry“) in an Object Merge SOP, the output of the previous timestep can be used as the starting point for the next timestep within the SOP Network.”
As this node exist since at least 10 years, does somebody know any tutorial, help material, free, paying, praying whatever ??
Thank you.
Explain SOP Solver dynamics node
820 0 1- Dav_Rod
- 40 posts
