Problems with editable nodes
   1878   3   1
I am having a problem with the editable nodes.
Attempting to use them to change a point attribute,
so one can choose different instancing/transformation methods per point, I get the following errors:
Committing Geo : HAPI Error: Unsupported storage type for attribute.
If session is invalid, try restarting Unity.
UnityEngine.Debug:LogError(Object)
HoudiniEngineUnity.HEU_SessionBase:SetSessionErrorMsg(String, Boolean) (at Assets/Plugins/HoudiniEngineUnity/Scripts/Sessions/HEU_SessionBase.cs:155)
HoudiniEngineUnity.HEU_SessionHAPI:HandleStatusResult(HAPI_Result, String, Boolean, Boolean) (at Assets/Plugins/HoudiniEngineUnity/Scripts/Sessions/HEU_SessionHAPI.cs:645)
HoudiniEngineUnity.HEU_SessionHAPI:CommitGeo(Int32) (at Assets/Plugins/HoudiniEngineUnity/Scripts/Sessions/HEU_SessionHAPI.cs:1622)
HoudiniEngineUnity.HEU_AttributesStore:UploadAttributeViaMeshInput(HEU_SessionBase, Int32, Int32) (at Assets/Plugins/HoudiniEngineUnity/Scripts/Attributes/HEU_AttributesStore.cs:603)
HoudiniEngineUnity.HEU_AttributesStore:SyncDirtyAttributesToHoudini(HEU_SessionBase) (at Assets/Plugins/HoudiniEngineUnity/Scripts/Attributes/HEU_AttributesStore.cs:278)
HoudiniEngineUnity.HEU_HoudiniAsset:UploadAttributeValues(HEU_SessionBase) (at Assets/Plugins/HoudiniEngineUnity/Scripts/Asset/HEU_HoudiniAsset.cs:1937)
HoudiniEngineUnity.HEU_HoudiniAsset:InternalStartRecook(Boolean, Boolean, Boolean, Boolean) (at Assets/Plugins/HoudiniEngineUnity/Scripts/Asset/HEU_HoudiniAsset.cs:1212)
HoudiniEngineUnity.HEU_HoudiniAsset:RecookBlocking(Boolean, Boolean, Boolean, Boolean) (at Assets/Plugins/HoudiniEngineUnity/Scripts/Asset/HEU_HoudiniAsset.cs:989)
HoudiniEngineUnity.HEU_HoudiniAsset:RequestCook(Boolean, Boolean, Boolean, Boolean) (at Assets/Plugins/HoudiniEngineUnity/Scripts/Asset/HEU_HoudiniAsset.cs:649)
HoudiniEngineUnity.HEU_HoudiniAssetUI:DrawSceneElements(HEU_HoudiniAsset) (at Assets/Plugins/HoudiniEngineUnity/Editor/UI/HEU_HoudiniAssetUI.cs:980)
HoudiniEngineUnity.HEU_HoudiniAssetUI:OnSceneGUI() (at Assets/Plugins/HoudiniEngineUnity/Editor/UI/HEU_HoudiniAssetUI.cs:262)
UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr)
and
Unable to upload custom attribute edits!
HoudiniEngineUnity.HEU_AttributesStore:SyncDirtyAttributesToHoudini(HEU_SessionBase) (at Assets/Plugins/HoudiniEngineUnity/Scripts/Attributes/HEU_AttributesStore.cs:280)
I am on Unity 2018.3.0b2 and Houdini 16.5.668.
Read through the documentation and tried different nodes. can't figure out what it is I am doing wrong here.
I attached my HDA below..
Edited by MartinBaadsgaard - Nov. 29, 2018 10:16:39
Fence_Maker_OBJ.hda (47.8 KB)
I am able to repro the issue, and am investigating it. Will let you know when its fixed.
Hi Martin,
The attribute upload error will be fixed in the next daily build (16.5.672, 17.0.418).
Great! Thank you!
