I use Copy To Points and want to provide the appropriate N at each point.
Based on what I have seen elsewhere, my approach was to
A. Facet the incoming geometry, generating an individual prim per polygon.
B. Then generate prim normals and
C. shrink each prim's points towards its barymetric center with a Primitive SOP (Transform, scale 0)
D. then a Fuse SOP to eliminate the duplicate points
Finally, I thought I could transfer the Prim normals (from B or C) to Point (from D) normals with an Attribute Transfer SOP
but it doesn't work… no normals appear on my points (per Geometry spreadsheet and scene view)
Should it or am I making the wrong assumptions about how Attribute Transfer works ?
