Is there anyway I can speed up my Voronoi Fracture? It takes up to 3 hours to fracture my object. I've created a volume from points and then converted that to geometry and am breaking that geometry up using a Voronoi Fracture node
I've attached my project
Thanks a lot
Josh
Voronoi Fracture Very slow.
2647 1 1- Josh Wibberley
- 13 posts
- Midasssilver
- 310 posts
It might be easier for you to work if you do an initial shatter with less points, say 20-50 pieces, then re-shatter that to the amount of pieces you need. This should help clean up any initial problems with the mesh, since it will become a good mesh if it shatters at 20-50 pieces. Then you can specify which of those pieces you want to shatter individually, or just shatter the entire thing, and see if that helps. Also, after looking at your scene, you are trying to shatter an object with 42000 pieces. That is going to take a long time, no matter what, but the good thing is, you only need it work properly once, then save that cached file.
