Is it possible to have a node take a 1+ single inputs followed by a merge input, similar to native DOP nodes?
For example, in the attached image, vopforce1 is a native node and accepts two inputs… but the 2nd input can have as many nodes fed into it as I want.
The node underneath it is similar except that the 2nd input only accepts a single node. What is interesting about this node is that I can't see any reason why that 2nd input shouldn't be exactly like the vopforce1 node… unless Houdini doesn't have support for doing this in custom nodes.
Thanks. [www.sidefx.com]
