During testing of my shader i have faced with a strange problem.
http://www.cgtalk.ru/forum/attachment.php?attachmentid=9127&d=1154022647 [cgtalk.ru]
Shader uses “metamarch” VEX function.
I have suspected that this function is guilty.
I wrote simple shader to check it.
http://www.cgtalk.ru/forum/attachment.php?attachmentid=9130&d=1154022811 [cgtalk.ru]
Bias = 1
Distance = 2.90487
Bias = 5
Distance 10.9049
But… in both cases i have got the same picture.
Looks like bias is performed along a viewing ray…after inersection is founded
http://www.cgtalk.ru/forum/attachment.php?attachmentid=9128&d=1154022693 [cgtalk.ru]
I hoped, that it should work as follows:
Extend metafield by bias first, then find intersection with extended metafield.
http://www.cgtalk.ru/forum/attachment.php?attachmentid=9129&d=1154022739 [cgtalk.ru]
VEX Metamarch bug?
8936 5 1- AndrewVK
- 136 posts
- Sven
- 13 posts
Could you try your border testrender with mantra -r option ( no micropoly rendering ) ? I have seen several problems in mantra with mp rendering that are gone with raytracing only over the last few month. For example http://odforce.net/forum/index.php?showtopic=4246. [odforce.net]
Sven
Sven
- AndrewVK
- 136 posts
- jesta
- 311 posts
- pbowmar
- 7024 posts
Nope, there is nothing “wrong” with it. I ran into this on Elektra. It's a bounding box problem. Basically, you're “displacing” the noise too far and trying to sample outside the bounding box of the metaball, which is always going to be undefined.
The way to fix this, apparently, is to displace the noise towards the centre of the metaball. However, I never got around to this. We just made the metaballs bigger with a smaller weighting and hoped for the best since we ran out of time… It was a big problem though.
If we're lucky “someone” will post the snippet of code that resolves this… if we're lucky )
Until a better solution comes along though, it's this or use i3D. Check out the 3rd party volumetrics solution mentioned elsewhere on the forum (bad brain, can't remember the name) which looked very cool.
Peter B
Peter B
- AndrewVK
- 136 posts
The way to fix this, apparently, is to displace the noise towards the centre of the metaball.The question is how to find this center
We just made the metaballs bigger with a smaller weighting and hoped for the best since we ran out of time…I also solve this problem with the same way.
If we're lucky “someone” will post the snippet of code that resolves this… if we're luckyDo You mean: “I know that ”someone“ solve this problem” ?????
