i'm looking for accessing to an HDA custom attributes in unity by script.
for example, my HDA contain a primitive attribute “address”(an integer)
is it possible to know in unity the value of this attribute for a specific primitive of my HDA ?
accessing to custom attributes
2677 8 1- chabis
- 9 posts
- seelan
- 571 posts
Search for `GetAttributeIntData` in the plugin's source code. It ends up calling HAPI_GetAttributeIntData which is documented here: https://www.sidefx.com/docs/hengine/_h_a_p_i_8h.html#addc0eb499a75e7764fcec857cd3e3814 [www.sidefx.com]
- chabis
- 9 posts
- chabis
- 9 posts
ok,
i've try to understand how to use it. i've read a lot, and understood a part, but after all, it's a fail for me: HAPI_GetAttributeIntData seem to be unknown.
below there's my code: (it's just some try to learn) in the first part, i'm trying to access to a parameter (and it's ok).
in the second part, i'm trying to access to an attribute but the last line is wrong (“HAPI_GetAttributeIntData does not exist in the current context”).
i've try a lot of way to write it, looking for examples, all is a fail …
can someone help me ?
HEU_HoudiniAssetRoot myroot = (HEU_HoudiniAssetRoot)curSelected.GetComponent<HEU_HoudiniAssetRoot>();
HEU_HoudiniAsset myhda = myroot._houdiniAsset;
// get parameters
HEU_ParameterData paramData = myhda.Parameters.GetParameter("princ_etages");
outvalue = paramData._intValues[0];
Debug.Log(outvalue);
// get attributes
HAPI_AttributeInfo attr_info;
attr_info.owner = HAPI_AttributeOwner.HAPI_ATTROWNER_PRIM;
attr_info.storage = HAPI_StorageType.HAPI_STORAGETYPE_INT;
attr_info.count = 0;
attr_info.tupleSize = 1;
HEU_AttributeData testdata = HAPI_GetAttributeIntData.GetAttributeIntData(null,0,0,"adresse", attr_info,0,1,0,1);
- seelan
- 571 posts
- chabis
- 9 posts
- chabis
- 9 posts
- seelan
- 571 posts
So you can use a helper to get your int attributes:
HEU_SessionBase session = GetHoudiniSession(true); HAPI_AttributeInfo addressAttrInfo = new HAPI_AttributeInfo(); int[] addressAttrData = new int[0]; HEU_GeneralUtility.GetAttribute(session, 0, 0, "address", ref addressAttrInfo, ref addressAttrData, session.GetAttributeIntData);
- chabis
- 9 posts
humm , after un long time, i'm trying to understand again…
i've try to use your example, and read again scripts and documentation..
at this time, i need to access to my asset and make a list of nodes and part, because unity answer that the ID i use is invalid.
i had a look of the examples in the plugin (HEU_ScriptMeshInputUVLayoutExample) but it's seem not to be what i need (or i Don't understand..)
so, my question is: how to know the ID of the node and the part ?
i've try with some default values like 0 or 1 , how that could be “invalid” ?
(in my example, “adress” is an attribute for every prim in my OTL.)
i've try to use HAPI_NodeInfo(),HAPI_GeoInfo() and HAPI_PartInfo() but at each time i need a nodeID.
in my mind, what i want to do (to know the value of an attributes of a prim) seem to be “the base” and i'm very confused.
thanks for your help seelan
