Asset not update obj position
   2177   1   0
I have a problem with a very simple asset: In houdini I create a simple bool node and use the object merge nodes as input
When I use the asset in c4d I insert two spheres and everything works, the bool is calculated but only when I insert the two spheres, if I move the spheres the asset does not update!
Can someone help me?
English is not my native language, sorry in advance for any misunderstanding!
you need to set the Object Merge Transform parameter to “into THIS object”
