Long story to explain why I need something like this. I've gotten way deeper in DOPs than I was expecting for this project. I need a way to deactivate a static object on a certain frame. Can't use an RBD (part of the long story and I'm using an RBD for something else).
How to I go about something like that? I tried plugging in enable solver node before static solver and it didn't take it.
It said connection to input 0 is the wrong type.
I also tried an active value node. Someone else helped with activation expressions because I don't know much about expressions and VEX yet.
Any suggestions are really appreciated!
Deactivate Static Solver? or static object during simulation?
3918 7 3- hopeschroers
- 57 posts
- tamte
- 8539 posts
- hopeschroers
- 57 posts
Thank you for responding! I'm not sure how to do that. I want to deactivate the object at frame 95.
Would I attach the Switch DOP to the static object and write the expression if($F>94, 0, 1) in the select input? or wher edo I write it? I attached a photo of my node tree. I havent created a set up with switch and null DOPs before.
- hopeschroers
- 57 posts
- tamte
- 8539 posts
yes, whatever you have now, just plug Null DOP into second input of switch1
and put expression:
NOTE: and I know that you see everyone appending Static Solvers in the setups, but you really don't need them, you have 2 of them and you can delete both if you want, will not change a thing on your setup
and put expression:
$F>94
into Select Input parameterNOTE: and I know that you see everyone appending Static Solvers in the setups, but you really don't need them, you have 2 of them and you can delete both if you want, will not change a thing on your setup
Edited by tamte - Jan. 12, 2019 21:34:20
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- hopeschroers
- 57 posts
- traileverse
- 355 posts
- traileverse
- 355 posts
