how to select particles by ID instead of PT?
4079 2 1- ouroboros1221
- 79 posts
- tamte
- 8539 posts
after you import particles in SOPs
- display node after which you want to delete and make sure your particles have i@id attribute present
- activate selection tool in the viewort (S and then 2)
- make sure Select Groups is active (9)
- click Cog menu on the Group and Attribute list that appeared in top-right
- choose Attributes/id
- select particles and hit delete
- it will create Blast node and populate Group with something like this:
- you can also populate your Group parm like this manually if you know which ids you want to delete
@id=1823,1787,1763,1747
Edited by tamte - Jan. 13, 2019 00:31:31
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- ouroboros1221
- 79 posts
