Noisy movement for template points
1625
3
1
Emil
Jan. 13, 2019 4:37 p.m.
Hi everyone, I want to give template points noisy movement just like vibrating molecules. How can I use the noise() function to make my template points randomly vibrate?
tamte
Jan. 14, 2019 5:28 a.m.
you can use Attribute Noise SOP
Tomas Slancik FX Supervisor Method Studios, NY
Emil
Jan. 14, 2019 6:16 a.m.
tamte you can use Attribute Noise SOPThank you Tomas for reply, it is a fantastic node but is specific only to H17, unfortunately I still use H16.
mrCatfish
Jan. 14, 2019 9:59 a.m.
In a point wrangle, you could put something like this:
@P +=noise (@P *1 + @Frame *.01 );
… however, it would be easier to put down a point vop and used one of the noises under the noise menu there.
Sean Lewkiw CG Supervisor Machine FX - Cinesite MTL
