I did not use VDB that much and I my main goal is to convert VDB with color information into poly with color.
I try a temporary pipeline that start from poly.
I set color on my primitive poly
I'm using the vdb from poly and ask for a volume attribute from my prim color attribute. The drop down menu enable me to setup the transfer very easily.
I can see the information and my node output contain 2 surfaces: surface & Cd
But then ?!? I know how to create a poly using the remesh node but is there any solution to get volume Cd information back ? For example making an attribute transfer ?
Unfortunately I fail in finding any solution to read info from the Cd & Surface VDB buffer and most of the regular “point” nodes did not access VDB buffer.
I'm wondering If need to work with Attribut VOP ? It's a Node I never play with…
Of course I don't want to attribute transfer from the original poly since I will not have this data information on a final prototype.
Please let me know any advise
Thanks,
FRED
Anyone using VDB and specific surface buffer ?
821 3 1- fhoude
- 8 posts
- tamte
- 8539 posts
- fhoude
- 8 posts
Thanks Tamte !
Will look at your hip file !
In the meanwhile, I try Vex Builder a little more and slowly began to see how it works
Have used one VolumeSample with success right now.
- filename input plug on my node OpInput 2 (VDBNode that contain Cd color surface)
- Select primitive Number as 2 (assuming this is the VDB channel index corresponding to VDB.Cd)
- VolumeSample Output plug to Output Cd input.
Only work on Point right now…
Will look at your file !
Next step will be “how to bake a texture depending on this VDB Color Attribute”
Will ask for help in I need it !
Thanks again !
FRED
Thanks again !
FRED
- fhoude
- 8 posts
