Making possible changing the Emission Color to match "Cd" or Diffuse Point Color from Classic Shader
   2812   2   0
Hi there,I am trying to use the attribute “Cd” not just as Diffuse Color on the shader but also as Color for the Emission. I check the Classic Mantra Shader and the Emission doesnt allow you to use the point color as Emission Color unluckily. Is there any way to do that? I thought about getting inside the shader and finding out the part of the shader affecting the Emission but it doesnt seem to work
Try connecting a ‘Surface Color’ node to the classic shader's emission color input. The surface color node can pick up point color.
Thanks, Ill try that
