DM 1.5 first screenshot:
https://i.postimg.cc/rcy3KY3v/dm1-5-screen.png [i.postimg.cc]
DM 1.5 for Houdini
4149 11 3- Alexey Vanzhula
- 538 posts
- Midphase
- 833 posts
Is it out? (don't say “soon”).
>>Kays
- Alexey Vanzhula
- 538 posts
- Alexey Vanzhula
- 538 posts
DM 1.5 zone menu system.
An example of how you can create your own customizable menus via shelf tools:
if not hasattr(hou, 'dm_menu'): from dm import ui, symmetry, simple_tools from dm.state_tools import push class DM_Menu(ui.ZoneMenu): font_size = 10 cell_width = 80 cell_height = 32 border_size = 1 font_color = 'black' left_color = '#555555' right_color = '#555555' top_color = '#444444' bottom_color = '#444444' left_right_offset = 0 opacity = 0.94 def build(self): # LEFT ZONE self.tool('Extract', simple_tools.extract, 'left', 1, 0) self.tool('Flip', simple_tools.flip, 'left', 1, 1) self.tool('Delete', simple_tools.delete, 'left', 1, 2) self.tool('Collapse', simple_tools.collapse, 'left', 1, 3) self.tool('Clean Edges', simple_tools.clean_edges, 'left', 1, 4) self.tool('Fix Overlaps', simple_tools.fix_overlaps, 'left', 1, 5) self.tool('Clip', simple_tools.clip, 'left', 1, 6) self.tool('Delete History', simple_tools.delete_history, 'left', 0, 0) self.tool('Clean History', simple_tools.clean_history, 'left', 0, 1) self.tool('Delete Nodes', simple_tools.delete_nodes, 'left', 0, 2) self.tool('Isolate', simple_tools.isolate, 'left', 0, 3) self.tool('Fix Normals', simple_tools.fix_normals, 'left', 0, 4) self.tool('Reduce', simple_tools.reduce, 'left', 0, 5) self.tool('Separate', simple_tools.separate, 'left', 0, 6) # RIGHT ZONE self.tool('Bevel', 'sop_polybevel::2.0', 'right', 0, 0) self.tool('Extrude', 'sop_polyextrude::2.0', 'right', 0, 1) self.tool('Inset', 'sop_polyextrude::2.0', 'right', 0, 2) self.tool('Split', simple_tools.split, 'right', 0, 3) self.tool('Loop', simple_tools.loop, 'right', 0, 4) self.tool('Connect', simple_tools.connect, 'right', 0, 5) self.tool('Mirror', simple_tools.mirror, 'right', 0, 6) self.tool('Knife', 'sop_knife', 'right', 1, 0) self.tool('Fill Quads', simple_tools.fill_quads, 'right', 1, 1) self.tool('Fill Polygon', simple_tools.fill_polygon, 'right', 1, 2) self.tool('Shell', 'sop_polyextrude::2.0', 'right', 1, 3) self.tool('Duplicate', simple_tools.duplicate, 'right', 1, 4) self.tool('Bridge', simple_tools.bridge, 'right', 1, 5) self.tool('Slice', simple_tools.slice, 'right', 1, 6) # TOP ZONE self.tool('Symmetry', symmetry.symmetry, 'top', 0, 0) self.tool('Instance', symmetry.instance, 'top', 1, 0) self.tool('ReSym', symmetry.resym, 'top', 2, 0) self.tool('Subd. Instance', symmetry.subdivide_instance, 'top', 3, 0) self.tool('Material', simple_tools.material, 'top', 4, 0) self.tool('Pick Material', simple_tools.pick_material, 'top', 5, 0) self.tool('Edit Material', simple_tools.edit_material, 'top', 6, 0) self.tool('Array', 'array', 'top', 0, 1) self.tool('Combine', simple_tools.combine, 'top', 1, 1) self.tool('Shatter', simple_tools.shatter, 'top', 2, 1) self.tool('Show Handle', simple_tools.show_handle, 'top', 3, 1) self.tool('Union', simple_tools.union, 'top', 4, 1) self.tool('Subtract', simple_tools.subtract, 'top', 5, 1) self.tool('Intersect', simple_tools.intersect, 'top', 6, 1) # BOTTOM ZONE self.tool('Center', simple_tools.center, 'bottom', 0, 0) self.tool('Center V', simple_tools.center_h, 'bottom', 1, 0) self.tool('Center H', simple_tools.center_v, 'bottom', 2, 0) self.tool('Push Points', push.start, 'bottom', 3, 0) self.tool('Smooth Brush', 'sop_polydraw', 'bottom', 4, 0) self.tool('PolyDraw', 'sop_polydraw', 'bottom', 5, 0) self.tool('Smooth Edges', 'sop_smooth_edges', 'bottom', 6, 0) self.tool('Flatten', simple_tools.flatten, 'bottom', 0, 1) self.tool('Flatten V', simple_tools.flatten_v, 'bottom', 1, 1) self.tool('Flatten H', simple_tools.flatten_h, 'bottom', 2, 1) self.tool('Size Deform', 'size_deform', 'bottom', 3, 1) self.tool('View Deform', 'view_deform', 'bottom', 4, 1) self.tool('Quick Deform', 'quick_deform', 'bottom', 5, 1) self.tool('Ramp Deform', 'ramp_deform', 'bottom', 6, 1) def gesture_right(self): simple_tools.set_selection_mode(hou.geometryType.Primitives) def gesture_left(self): simple_tools.set_selection_mode(hou.geometryType.Edges) def gesture_bottom(self): simple_tools.set_selection_mode(hou.geometryType.Points) def gesture_top(self): simple_tools.set_selection_mode() hou.dm_menu = DM_Menu() hou.dm_menu.start()
Edited by Alexey Vanzhula - Feb. 19, 2019 04:15:52
- Midphase
- 833 posts
Alexey, you make awesome tools and everything you do is very appreciated. I hope you will consider taking the time to add proper documentation since to this day I feel like I'm probably utilizing 10% of DM because I haven't quite been about to figure out how it all works.
I realize that your English might not be good enough for you to feel comfortable doing extensive tutorials, but if that's the case, please do consider asking someone else to do a series of tutorials for you. I think that would go a long way toward making your product a lot more popular and useful.
>>Kays
- Alexey Vanzhula
- 538 posts
Midphase
I'm going to record a series of tutorials in Russian and English
Edited by Alexey Vanzhula - Feb. 19, 2019 04:17:19
- Werner Ziemerink
- 1265 posts
- sburke
- 9 posts
- Palipala
- 21 posts
- Alexey Vanzhula
- 538 posts
- Alexey Vanzhula
- 538 posts
- Palipala
- 21 posts
