I am reading a compress fluid cache file , doing some SOP magic and outputting my ocean as a bgeo.sc
I run this in a cmd line using hbatch in order not to load any geo into the UI (it actually saves tons of memory).
But what I notice is that the memory does not clear at each frame. Which it would be convenient since the the fluid cache is already written and I feel it pushes memory use for no reason. I may be wrong, yes sometimes it happens , but could this be the case?
is there a command I can use to force clear the memory at each frame. Right now what I do is basically close the hipfile and mread the file every 25 frames so memory gets “cleared” bt it does feel overkill.
Any ideas, anyone had experience similar issue?
Nico.
clearing the memory at each frame?
1384 0 1- Nicolas Heluani
- 280 posts
