Hi!
I've created a new asset (Asset -> New Digital Asset From Selection…) and chose a path where to save it. Now I'm making a bunch of changes inside the Subnet and I was wondering if Houdini saved everytime I make changes or do I have to be in the Type Properties window and click Accept?
-Olivier
Asset creation: when does it save?
2911 5 0- olivierth
- 1007 posts
- goldfarb
- 3455 posts
- olivierth
- 1007 posts
- BabaJ
- 2038 posts
It never automatically saves…to update your new changes you have to use “Save Node Type”.
If your working on your asset and have made some changes, but change your mind…use “Match Current Definition”,
in which case it will remove all these changes you had been making and set the asset to the last time you did a “Save Node Type”,
or if you hadn't done that yet with the asset, the same set up when you first created the asset.
- olivierth
- 1007 posts
- tamte
- 8548 posts
