Hello-
I've been experiencing frequent program crashes. I've learned to save often! Is this something Houdini users just put up with, should I report the specific crashes, is there some setting adjustment I can make, etc….?
-Scott
Frequent program crashes
1106 2 0- scottval
- 56 posts
- Enivob
- 2534 posts
Program crashes are often the result of bad hardware. Sometimes bad memory, or an overclocked system will cause frequent crashes. When I first started using Houdini, it crashed a lot. As I learned the software, it crashed less an less because I did not do the wrong thing as often (i.e wire up things wrong, or generate ridiculous simulation sizes). Try not to exceed your physical memory and keep an eye on the heat generated by your system.
Feel free to report your crash logs, however.
Edited by Enivob - April 8, 2019 20:47:05
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- jerry7
- 620 posts
If you can repeat the crash operation, please submit the BUG report.
https://www.sidefx.com/bugs/submit/ [www.sidefx.com]
