Hi All!
I am not sure what the real problem, but when i start up my Linux i try to run Houdini, it starts checking for license server, end up not being able to connect to server, but hserver is running, it tells me everything is failed and all red check boxes.
I have installed correctly in default location /opt/houdinig etc.
So in order to start Houdini back again, i have to remove whole license directory and start installing license back again, then it works!
i remove constantly license from /usr/lib/sesi.
I don't understand why this happens, and what should i do to avoid this problem over again!
Hkey on Suse Linux
3668 2 1- xcomb
- 74 posts
- tallkien
- 225 posts
run a SUSE search on these forums. There's a lot of info on the subject. Most probably your sesinetd is not starting up on boot. You don't need to reinstall the license each time. I had the same problem. I tried all kinds of tips mentioned elsewhere in these forms but what ultimately worked was this
Login as root, go to yast->System->System Services (Runlevel) and find sesinetd.startup there and enable it in runlevel 2.
Hope this helps
cheers
Hope this helps
cheers
- xcomb
- 74 posts
