Is there such a thing as being able to have the texporter “echo all commands”
Rob
texporter
6797 7 3- circusmonkey
- 2624 posts
- Le_monkey_butt
- 166 posts
If you meant to print out all the available commands in the Textport:
There is ‘help’ which will print out all the commands and ‘exhelp’ which will print out all the expression commands.
You can use the ‘-k’ flag if you want to print all the commands related to a keyword.
Time to get out of this messy world.
- circusmonkey
- 2624 posts
- Le_monkey_butt
- 166 posts
But you can:
for example in your script ( blabla.cmd ): you use ‘opadd’ to add an operator, and ‘opparm’ to set/get the parameters of your op. Then ‘opwire’ to wire your op together.
Finally in the textport you type 'source /blabla.cmd' and voila! Although that ‘source’ can be skipped, I think. I guess you could have a look at ‘123.cmd’ and for any usage of ‘opparm’, etc, type help opparm.
Also you can put down and an operator using ‘TAB’ then type ‘opscript’ it will give the script for what you ve just done.
- pbowmar
- 7024 posts
- Simon
- 2199 posts
- goldfarb
- 3455 posts
- circusmonkey
- 2624 posts
