I am having trouble getting a non-commercial license for Houdini Master 8.1.704. The automatic configuration will not retrieve the license, and manually visiting http://license.sidefx.com/get_nc_license.php [license.sidefx.com] returns the error:
ERROR: Could not generate server key
Below is the diagnostics output. Can anyone help, please?
Thanks,
Matt.
Diagnostic Output:
If you are having licensing problems, please save this information and email it
to support@sidefx.com.
License Administrator output:
Generated on: Tue Sep 19 14:17:09 2006
Local host name: RED79
Local server code: 0315e36f
Local ip address: 127.0.0.1
Number of servers: 1
License server name: red79 (red79)
License server server code: 0315e36f
Server ip address: 127.0.0.1
License server is running: Yes
May read licenses from server: Yes
Has SERVER license: No
License server version: 8.1.704
May modify server from this machine: Yes
Redundant server keys: 0
Name Code Redundant Connected Transmission OK
License Administrator version: 8.1.704
Http proxy host: (none)
Using standalone mode: Yes
Can retrieve http://license.sidefx.com/index.php: [license.sidefx.com] Yes
Installed licenses:
LicID Platform Product Ver Avail Expiry
sesictrl -i output:
—– SERVER red79 ——–
*** WARNING *** - No valid server lines found
hserver -l output:
Hostname: RED79
Uptime: 0:43:59
License Server: red79
Server Version: sesinetd8.1.704
Version: Houdini8.1.704
ReadAccess: +.+.+.*
WriteAccess: +.+.+.*
192 of 511 Mb available
CPU Usage: 2% load
0 active tasks (1 slots)
licenses file:
* Could not open the licenses file. *
