UV size on different objects
   2422   1   0
Hey guys
Do u know any solution to my next problem?
I'have seen in Max how different objects can be assigned the same relative UV size using the MapScale modifier. It's a great feature when creating UV masp for different objects, no need to use any checker pattern to adjust the UV sizes within each obj geometry.
Thanx in advance
Cheers
I'm not sure how the MapScale Modifier works but in Houdini try the UVTransform SOP (and scale parameter).
