how could i find out which Option of my Selectionbox is selected ?
i've created a Selector Parameter
static PRM_Name singleParticleDrawOptionNames =
PRM_Name(“drawParticleComponentNone” ,“none”),
PRM_Name(“drawParticleComponentSpring” ,“Springs”),
PRM_Name(“drawParticleComponentDisplacement” ,“Displacement Vectors”),
PRM_Name(“drawParticleComponentAll” ,“all”),
PRM_Name(0)
static PRM_Name displayNames =
PRM_Name(“drawParticleCSelector” ,“Draw Components”),
PRM_Name(0)
PRM_ChoiceList specparticleDrawOptions(PRM_CHOICELIST_SINGLE,singleParticleDrawOptionNames);
PRM_Template(PRM_INT, 1, &displayNames,0,&specparticleDrawOptions)
i tried to access the stuff using
int DRAWPARTICLECOMPONENT_SPRING(VOID) { INT_PARM(“drawParticleComponentSpring” ,ILF_DRAWPARTICLECOMPONENT_SPRING, 0, 0) };
but it doesnt work,
i always got an error message telling me:
frequenzForce1 evalInt: Invalid parameter index drawParticleComponentSpring
can somebody please tell me how to get the Options which are selected ??
thx in Advance
Sebastian
API - find out which Option is selected
3602 4 0- Infernalspawn
- 229 posts
- malexander
- 5156 posts
You have to query the parm name, not the menu item name.
so:
INT_PARM(“drawParticleCSelector”, ILF_DRAWPARTICLECOMPONENT, 0, 0) };
will tell you the index of the selected option (for Springs, index=1). Only one option can be selected at a time (otherwise, you'd have to use a series of PRM_TOGGLE parms).
so:
- edward
- 7714 posts
Personally, I find it a lot easier to just use the eval*() versions of the functions that use the parameter name. A lot less prone to error even if they are less efficient. And if you only evaluate your parameters once per cook, there's very little to lose. And if you really do find it to be a bottleneck, you always easily switch to the index versions later.
- Infernalspawn
- 229 posts
actualy the code you've posted didnt work out, but i was wondering if the
enum i've created
enum POP_FrequenzTestIndex
ILF_ACTIVATE, // 0
ILF_SOURCE, // 1
ILF_ORIGIN, // 2
ILF_DIR, // 3
ILF_RADIUS, // 4
ILF_LENGTH, // 5
ILF_STRENGTH, // 6
ILF_IGNOREMASS, // 7
ILF_OVERRIDEMASS, // 8
ILF_MASS, // 9
ILF_GRAVITY, // 10
ILF_INTERACTIONRADIUS, // 11
and using this elements to access UI elements are somehow connetected.
So the ordering of this enum elements and the appearance of the UI elements when i create them, maybe connected somehow or something like this ?? is this possible or what do i need these enum stuff for ???
thx in advance
Sebastian
enum i've created
ILF_ACTIVATE, // 0
ILF_SOURCE, // 1
ILF_ORIGIN, // 2
ILF_DIR, // 3
ILF_RADIUS, // 4
ILF_LENGTH, // 5
ILF_STRENGTH, // 6
ILF_MASS, // 9
ILF_GRAVITY, // 10
thx in advance
Sebastian
- malexander
- 5156 posts
