Hi guys,
For one of my final uni projects I'm destroying a house. One key layer of the house is the wood frame, it's fractured and everything but every single wood piece fly's off upon collision (which makes sense)is there a way to cluster some of the wood pieces together to make wood break apart in chunks to make the sim more realistic? Instead of every single splinter flying off?
I messed around with RBD cluster and glue cluster with not much luck
Thanks in advanced!
Clustering wood fractures?
1394 3 0- william131997
- 2 posts
- mrCatfish
- 731 posts
- william131997
- 2 posts
mrCatfish
You should get constraints coming out of the RBD material fracture SOP, and furthermore you should be able to cluster them inside that SOP or afterwards with a glue cluster. Can you post a hip file?
The wood was fractured manually with a normal vorinoi transom setup. But yes sorry my bad, here is the hip evetything should be in the fracture
Edited by william131997 - April 17, 2019 12:38:36
- mrCatfish
- 731 posts
I took a look at your file but it's got a whole bunch of file cache nodes that break when it's opened. It would be a lot of work to fix them all. If you can post one without all those nodes, (replace with stash nodes), then it will be a lot easier for other people to figure out.
Sean Lewkiw
Machine FX - Cinesite MTL
