bbox based on the previous element
   1140   2   1
I would like to create a stack with some pieces of geometry and scale down each of them based on the previous bbox. The final look should be like a pyramid based on the geometry you are using .. something like that:
__
_|__|_
_|______|_
|__________|
My problem is that I haven't been able to figure out the correct VEX syntax to use a point wrangle and read the bbox from the previous iteration. Any help out there?
Might be something here you can steal from:
http://www.tokeru.com/cgwiki/index.php?title=ForLoops#Stacking_boxes [www.tokeru.com]
Hey mestela, thanks for the link.
I already saw this link I was planing to follow a different approach but I will try to make it work with the setup from tokeru.
cheers
