How to set Hair Generate render density?
1880 4 1- YasinH
- 55 posts
- YasinH
- 55 posts
- mestela
- 1737 posts
You could do it in several ways. Leave the render hair hidden, but use the force objects parameter in your rop to only turn it on at render time. Or if you're using a sops hair workflow rather than the high level obj system created by the shelf tools, you can split your display (blue) and render (purple) flags in sops to do a similar trick.
Edited by mestela - April 19, 2019 07:50:09
- YasinH
- 55 posts
mestelaThanks for the tips. I think I'm gonna stick with the force parameter for now. I'm quite new to Houdini, so it would take some time until i can figure out how to do the display/render separations myself.
- CarloB
- 20 posts
