Is it possible to add a ramp masking option to the Guide Groom node so that we can groom hair tips and roots without affecting each other? This is equivalent to the Fibermesh masking in ZBrush.
Feature request | Guide masking along length
1201 3 2- YasinH
- 55 posts
- bonsak
- 459 posts
- YasinH
- 55 posts
bonsakThanks for the reply. I was hoping to use the masking on the Guide Groom node itself so that it works with its grooming brushes (e.g. screen brush). If I use a Guide Process, how do I pipe the mask to the Guide Groom?
On a Guide Process node, go to the Masking tab and check Use Curve Mask.
You can also define your own “mask” attributes on the guides and pipe them in via the Blend dropdown.
Regards
Bonsak
- bonsak
- 459 posts
