How can I group similar polygon shells based on vertices/points count?
Group similar shells
1965 4 1- YasinH
- 55 posts
- anon_user_40689665
- 648 posts
- YasinH
- 55 posts
cpbThanks for the reply. It seems to be doing what I was asking although the shells in one cluster don't have exactly same vertex count which is probably a matter of tweaking parameters? I wish there was an easier way to do it as the clustering attribute vop seems quite complex. Isn't there a way to do the clustering with the built-in cluster node?
see attached,
using partition sop to grab the segment attribute.
- 648 posts
- YasinH
- 55 posts
