I would need to know how I can transfer the color of an object in motion. To another object in motion. And that the color is permanent. I've tried it with the solver node, but it freezes the animation.
Thank you very much, sorry for my English. I am Spanish.
attribute transfer color
2426 7 2- SerranoMan
- 4 posts
- krueger
- 191 posts
- Midasssilver
- 310 posts
- SerranoMan
- 4 posts
- SerranoMan
- 4 posts
Midasssilver
Post a hip! It should work, so there's probably something wrong you are doing in your scene.
I also upload the alembic file.
I'm learning houdini
Thanks a lot!
https://drive.google.com/file/d/1P5hll_g5RjFFmzWxBFK9ZlZaEvelFDjj/view?usp=sharing [drive.google.com]
Edited by SerranoMan - May 22, 2019 04:34:33
- Midasssilver
- 310 posts
- SerranoMan
- 4 posts
- Midasssilver
- 310 posts
With the change to the solver I made, the main difference to get it to work was which color you had on each branch feeding into the solver. Since we are adding color every frame, we need to add the color that can be added. We can add white to black, but we can't add black to white, since that would be the same as adding 0. Once I flipped which color was on which side, it worked.
