For Each sorting issues
1809 4 2- antonsfx
- 8 posts
Heyho,
currently, I have a problem with the For each and sorting nodes.
I want some Alembic model sort over the Z-axis and then animated them from start point to end point separately with the timeshift upwards.
But I don´t get it working, probably something simple but I don´t find the issue.
I made an example for that and the file is attached, can someone help,
Edited by antonsfx - June 1, 2019 17:40:03
- BabaJ
- 2036 posts
- jsmack
- 7737 posts
- goldleaf
- 4159 posts
I haven't found timeShift + foreach super intuitive (I feel like I have to re-learn it every time I use it. But in this case, if you are offsetting some animation, there are some attributes you can use for both packed prims and alembic packed prims, for offsetting time on different copies of an animated prim.
This odforce post links to the video + example: https://forums.odforce.net/topic/31923-arnesen-cubes-in-houdini/ [forums.odforce.net]
Hope that helps!
*edit*
Hope that helps!
*edit*
What jsmack said
Edited by goldleaf - June 1, 2019 20:10:24
I'm o.d.d.
- antonsfx
- 8 posts
