parm.parmTemplate().type()
But it turns out that you can build a menu from integers and string parameters as well, if you check the toggle “use menu”.
The thing to be aware of is that if you ask for their .type() they would be seen as `string` or `int`.
So how to check if a parameter has a menu?
I'm using a try/except solution:
try: parm.menuItems() print "this is a menu" except: print "this is not a menu"
My questions:
1) This seems to work but maybe is there a better method to do it?
2) Is there any practical difference between and ordered menu and a integer menu? They seem to be the same.
I attached the hip file with the examples.
thanks for any help,
cheers
