I want to make this effect in houdini
https://www.youtube.com/watch?v=xj0rZe0qMMU [www.youtube.com]
what I tried
I tried to calculate distance and scatter point but as I noob I couldn't make like attached effect
I need a way to distort hexagon shapes
How can I make something like this?
1964 5 0- smkplus3d
- 3 posts
- Kate Xagoraris
- 46 posts
- BabaJ
- 2036 posts
- smkplus3d
- 3 posts
- smkplus3d
- 3 posts
- BabaJ
- 2036 posts
I had another look at your reference image because I was thinking the same ( how to connect the hexagons.)
But also, in your reference image the entire topology seems to follow a distorted sphere.
One approach was to use the mountain sop on a distorted sphere and then with some vex write the same hex to circle approach as it spans out across the surface.
I didn't do that. I felt it was going to take too much time as I'm working on other stuff.
But one way to fudge it is perhaps like I did with the different hex examples is use just the one distorted sphere and project a number of the hexes and using a curve sop with snap to points, fill in the gaps?
The following hip contains an embedded asset(under TAB menu Digitial Assets > Concentric Hexes) so you can populate the sphere with hexagons at different locations. Look at the controls tab of the asset so you can adjust where on the sphere the hexes project.
And as I just mentioned, just use curve sops to fill in the ‘gaps’.
As a point of refinement - I don't like how each copy iteration is scaling the size based on previous size. I would perhaps use my own method in for loop blocks to define the scaling per iteration.
Edited by BabaJ - June 29, 2019 12:09:43
