Hi Guys,
Im trying to achieve this stepped layering effect on my mesh and figured the correct approach woould be to use a shatter boolean with multiple cubes (which i have colored differently) and then transfer my Cd attributes across however although i am getting the hoirzontal cuts across my mesh in the correct place as intended, the color transfer is offset (almost as if my exactly half of the original cubes height)
Why is this occuring / how can i make sure the color transfer occurs only between the cut lines ?
Thanks in advance guys!
Why is my Color Transfer Offset?
857 0 0- DominicSewell
- 11 posts
