I 'd like to report two bugs. After working for some time in one, maximize viewport, during selection picking after I right click to accept selection I loose all of the selected points, and whatever I try I am not allowed to finish selection. The workaround for that is to (space-T) go to the 4 viewports and right click in one of the another window.
The other problem I experience happens only in double monitor - vertical configuration (horizontal is much stable). After pressing TAB and D or typin any command starting from that letter Houdini often crashes. C letter is also quite unstable but has crushed only several times. I am 100% sure that the problem lays in graphic cards drivers. Just to let you know about that.
Graphic Card: Nvidia Quadro FX 1400
version: Houdini 8.1.704
cheers
kuba
2 annoying bugs
3312 2 0- kuba
- 345 posts
- negow
- 27 posts
yes! i knew it was i bug. D i'm having the exact same issue (i.e. with the selecting), same houdini version (also apprentice), only a slightly different graphics card (FX 3450/4000 SDI).
Downdating my graphic card pronto.
edit after the bold attempt of downgrading my graphics drivers from latest (v91.36) to v77.56 i declare success D. Houdini makes much more sense now.
- kuba
- 345 posts
