I can use fit in an expression, but it clamps the values… so I want to use efit, but that doesn't seem to work in an expression.
I can work around the problem by using an attribute wrangle to store a detail attribute and then do a detail expression on the parameter I want, but that feels like an awkward solution. I'm wondering if there are better ways to do that?
efit in expression
1343 2 0- MathieuLeclaire
- 79 posts
- probiner
- 337 posts
Sorry to hear about this, one way to curb it is to do your own expression and efit is fairly straight forward. So given the values:
value = 4
inmin = 1
inmax = 3
outmin = 6
outmax = 8
the expression (4-1)/(3-1)*(8-6)+6 will give you 9, because 9 is to the 6→8 range, as 4 is to the 1→3 range, if it was clamped it would be 8. In other venues this operation can be called map or remap or rescale.
You could file an RFE for the function.
Cheers
value = 4
inmin = 1
inmax = 3
outmin = 6
outmax = 8
Cheers
Edited by probiner - Sept. 19, 2019 18:51:20
- jsmack
- 7659 posts
