Uninstancing
   343   3   2
so uninstancing in Houdini is a bit tricky. But I was thinking could it be done with a for loop and copy? See attached image. So I have instance points with all attributes coming in and on the left side I have geometry that gets copied. What expression do I need to put in the path to read the instance attribute from points and dynamically change the path per point? thank you
object path.JPG (76.2 KB)
I'm not sure if this will work with a string based attribute but try this in the Object1 field.
point("../foreach_begin1/",0,"path",0)
Edited by Enivob - Sept. 20, 2019 08:39:10
Using Houdini Indie
Ubuntu 18.04 48GB Ryzen 16 core.
nVidia 1070GTX 8BG RAM
If your instance paths are already defined as a point attribute, you can just feed it into the Instance SOP. There's an option there for “Instance Attribute”… this can be a string that points to either a file on disk, or a SOP path using op:/ syntax.
Hey guys. Thanks for the help!
Enivob - It didn't work but I watched this video and figured it out. Thanks for the help!
