Measure SOP expression help.
   1135   2   0
Hi all,
I have a 6 sided shape extruded shape, I'm using the Measure SOP to return an index of the area of each polygon. I want to select the largest poly and blast the rest.
I'm using “@area<350” in the Blast SOP to grab the biggest face from the index, but what I really want to do is select the largest face to make it 100% procedural…
Does anyone know the correct expression here for selecting biggest face in the index?
I would promote the area attribute to detail and choose max. Than you can refer to that maximum value within the blast SOP.
use Sort SOP to sort by area in reverse and keep the first
FX Supervisor
Method Studios, NY
