LIDAR scan look recreation problem
1643 6 1- Precar_Dan
- 11 posts
I'm trying to recreate the view of a LIDAR scan in the woods (reference in attachment). For the test, I loaded several tree types as Packed Geometry and distributed them across the plane. Next I want to add various bumps, rocks and branches for detail.
The most obvious solution for lidar simulation was to use POP Solver. This decision seemed like a very long time in the simulation to me, but maybe I'm doing something wrong. I also ran into a problem: Packed geometry is not defined as a collider object by particles. It is important for me to maintain high detail of objects
Are there more elegant solutions to this problem?
I came up with the idea to do point-scattering on each geometry, then pack the points in the final scene and do something like backface-culling for the object (conditional LIDAR). Q: how to do this for Packed geometry?
- Konstantin Magnus
- 670 posts
How about you unpack the geometry, place some high resolution spheres, keep only their points and shoot those into the scene with a Ray SOP?
Edited by Konstantin Magnus - Oct. 16, 2019 07:54:53
- Precar_Dan
- 11 posts
- Konstantin Magnus
- 670 posts
Here is an example file if someone needs it.
- Konstantin Magnus
- 670 posts
- Precar_Dan
- 11 posts
- Konstantin Magnus
- 670 posts
Here is a tutorial on creating the Lidar 3D scanning look: https://youtu.be/IbZRDFSz9hQ [youtu.be]
