Hello guys, im trying to use the voronoi fracture on a clipped box, and I use the isooffset and then the scatter but it creates me points inside my box, and i just want those points to be on the surface so i can break it and the pieces can fall inside the box.
So my question is: how do i create those points with the scatter just on the surface?
My main idea was to throw a ball and keep breaking the different walls, im going to atach the project, hope some1 can help me.
Trouble creating Volume on a clipped box
951 2 1- ixXe
- 9 posts
- Enivob
- 2531 posts
Check Output Back on the polyextrude1 node and disable the isooffset. The scatter will only scatter onto the surface of polygons. If you supply a volume, from the isooffset, it will scatter into the interior of the volume as well.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- ixXe
- 9 posts
