I'm considering buying this machine for using Houdini more seriously, does anyone see any issues I might have missed? I'm a bit confused about motherboard compatibility, I also have a usb-c monitor which I think will work with the GPU and motherboard but I'm a bit confused
Does it look powerful enough as well? I'm planning to use redshift, I wan to do some velum and sim work but nothing too intense, someone said I should get 128gb memory but that's a bit out of my price range right now
Thanks in advance!
CPU: AMD Ryzen 9 3900X - 12-Core 3.80GHz, 4.6GHz Turbo - 64MB L3 Cache Processor, Pro OC Compatible (No On-board Graphics)
GPU: MSI GeForce® RTX 2080 Ti 11GB - Ray Tracing Technology, DX12®, VR Ready, HDMI, DP, 4 Monitor Support (Single Card)
MEMORY: 64GB (4x16GB) DDR4/3200mhz Dual Channel Memory (HyperX Fury w/Heat Spreader)
MOTHERBOARD: ASUS ROG Crosshair VIII Hero: ATX w/ RGB, PCIe 4.0, USB 3.2, SATA3, 2x M.2
CAS: Fractal Design Define S Silent ATX Mid-Tower, Black
SSD: 1TB Samsung 860 QVO 2.5" SSD - 550MB/s Read / 520MB/s Write (1 Drive)
CS_FAN: Maximum Airflow with 3 x 120mm Black Cooling Fans for your selected case
FAN: AMD Ryzen Wraith CPU Cooler
NETWORK: ONBOARD 10/100/1000 GIGABIT LAN PORT – As standard on all PCs
POWERSUPPLY: Corsair Vengeance Series 650M 650W 80+ Silver Gaming Power Supply
Any thoughts on this potential machine?
521 0 0- altestudio
- 3 posts
