Hi all,
Using a Heightfield File node
I input a GeoTIFF and then use match size node with an .obj
This creates should creates an accurately sized Heightfield for me to work with.
When I try run this step in Unity via the Houdini Engine, an empty object is created with the HEU_GEO Sync (Script) on it.
The File Path is correct.
Under Sync / Unload, I have:
Log: ERROR: Unable to generate terrain data from volume parts.
Could anyone please help?
Heightfield File
2448 4 1- Alex Amos
- 28 posts
- seelan
- 571 posts
There is probably another error line above the one you posted which logs the actual error. It looks like either you aren't using a square size (same width and length), or its not a valid heightfield. Is the output node's info panel showing valid heightfield properties? Please post a screenshot of it.
Edited by seelan - Oct. 21, 2019 17:16:37
- Alex Amos
- 28 posts
Hi seelan,
Thanks for your reply.
Where would I find this line above? I dont seem to be able to find another place where there are errors showing for this.
Does the incoming heightfield need to be a 100% square ? at the moment, it is off by a few units.
I believe it is - It has all 18 Attrs that a freshly created Heightfield has, please see the attached snip for more detail.
seelan
seelan
seelan
- seelan
- 571 posts
Looks like it is using a 740x733 sized heightfield which Unity doesn't support. It needs to be a power of 2 + 1 size. Please see https://www.sidefx.com/docs/unity/_terrain.html#Terrain_Size [www.sidefx.com]
- Alex Amos
- 28 posts
Hi seelan,
Thanks for the reply again - I didnt realize that the masks need to be to the power of 2 + 1 - after I saw your last message, I did my best to try to “squarize” the terrain without scaling it (I cropped it down)
I now see that the GeoTIFF that I am using was not square and is at super low resolution, which I am sure has been my problem since the beginning.
I'll see if I can get a bigger and square one and will provide feedback
Thanks again <3
Thanks again <3
