I took a look at forum for this issue but could not locate any related answer which is very strange, I must be missing an obvious point.
I am trying to call a QDialog in Houdini it seems like the dialog functionality works however it leaves a trail behind when I move the dialog window. So, I tried with a very basic shelf tool that does nothing but still have this strange behaviour.
Here is the dummy code I use.
import hou from PySide2 import QtWidgets dialog = QtWidgets.QDialog(hou.ui.mainQtWindow()) dialog.exec_()
When I change dialog.exec_() to dialog.show() the trailing issue resolves but then I loose some functionalities of QDialog.
Is that a known issue or am I missing something?
Can someone lead me towards the correct direction to get the answer?
Best
